Sébastien Tordeux
nullAssociate Professor
email : sebastien.tordeux@inria.fr
Tel : +33 6 60 13 65 40
Postal Adress :
Université de Pau — IPRA
Avenue de l’Université,
BP 1155
64013 PAU CEDEX
FRANCE
My office :
UFR Sciences, Bâtiment B1
2ème étage, Magique 3D
Articles in Peer Reviewed Journals
Publications HAL de Sébastien,Tordeux
2024
titre
Optimised Correction Polynomial Functions for the Flux Reconstruction Method in Time-Harmonic Electromagnetism
auteur
Matthias Rivet, Sébastien Pernet, Sébastien Tordeux
article
Applied Mathematics Letters, 2024, 157, pp.109187. ⟨10.1016/j.aml.2024.109187⟩
Accès au texte intégral et bibtex
https://inria.hal.science/hal-04517554/file/AML_HAL_Rivet_Pernet_Tordeux.pdf BibTex
2023
titre
Ultra-weak variational formulation for heterogeneous maxwell problem in the context of high performance computing
auteur
Sébastien Pernet, Margot Sirdey, Sébastien Tordeux
article
ESAIM: Proceedings and Surveys, 2023, 75, pp.96-121. ⟨10.1051/proc/202375096⟩
https://hal.science/hal-03642116/file/ARTICLE_SMAI_REV.pdf BibTex
titre
Construction and analysis of a HDG solution for the total-flux-formulation of the convected Helmholtz equation
auteur
Hélène Barucq, Nathan Rouxelin, Sébastien Tordeux
article
Mathematics of Computation, 2023, 92 (343), pp.2097-2131. ⟨10.1090/mcom/3850⟩
https://hal.science/hal-04006555/file/preprint_hdg_tot.pdf BibTex
2022
titre
Low-order Prandtl-Glauert-Lorentz based Absorbing Boundary Conditions for the convected Helmholtz equation
auteur
article
Journal of Computational Physics, 2022, 468, ⟨10.1016/j.jcp.2022.111450⟩
https://inria.hal.science/hal-03288930/file/paper_lorentz_v2.pdf BibTex
2021
titre
Local strategies for improving the conditioning of the plane-wave Ultra-Weak Variational Formulation
auteur
Hélène Barucq, Abderrahmane Bendali, Julien Diaz, Sébastien Tordeux
article
Journal of Computational Physics, 2021, 441, pp.110449. ⟨10.1016/j.jcp.2021.110449⟩
https://inria.hal.science/hal-03235684/file/jcomp-d-20-01582.pdf BibTex
titre
Asymptotic behavior of acoustic waves scattered by very small obstacles
auteur
Hélène Barucq, Julien Diaz, Vanessa Mattesi, Sébastien Tordeux
article
ESAIM: Mathematical Modelling and Numerical Analysis, 2021, 55, pp.705 – 731. ⟨10.1051/m2an/2020047⟩
https://hal.science/hal-01250654/file/M2AN_BDMT_2020.pdf BibTex
2020
titre
Extension of the Günter derivatives to Lipschitz domains and application to the boundary potentials of elastic waves
auteur
Abderrahmane Bendali, Sébastien Tordeux, Yuriy Matveevich Volchkov
article
Journal of Applied Mechanics and Technical Physics, 2020, 61 (1), pp.21. ⟨10.1134/S0021894420010150⟩
https://hal.science/hal-01395952/file/gunter_bt.pdf https://hal.science/hal-01395952/file/gunter_bt%28rus%29.pdf BibTex
titre
Equivalent multipolar point-source modeling of small spheres for fast and accurate electromagnetic wave scattering computations
auteur
Justine Labat, Victor Péron, Sébastien Tordeux
article
Wave Motion, 2020, ⟨10.1016/j.wavemoti.2019.102409⟩
https://hal.science/hal-02139201/file/Preprint_Hal.pdf BibTex
titre
A discontinuous Galerkin Trefftz type method for solving the two dimensional Maxwell equations
auteur
Håkon Sem Fure, Sébastien Pernet, Margot Sirdey, Sébastien Tordeux
article
SN Partial Differential Equations and Applications, 2020, 1 (23), pp.19. ⟨10.1007/s42985-020-00024-0⟩
https://inria.hal.science/hal-02899350/file/preprint_FPST_SN_PDE.pdf BibTex
2019
titre
Sparsified discrete wave problem involving radiation condition on a prolate spheroidal surface
auteur
Hélène Barucq, M’Barek Fares, Carola Kruse, Sébastien Tordeux
article
IMA Journal of Numerical Analysis, 2019, ⟨10.1093/imanum/drn000⟩
https://inria.hal.science/hal-02386957/file/main.pdf BibTex
2017
titre
A Symmetric Trefftz-DG formulation based on a local boundary element method for the solution of the Helmholtz equation
auteur
Hélène Barucq, Abderrahmane Bendali, M’Barek Fares, Vanessa Mattesi, Sébastien Tordeux
article
Journal of Computational Physics, 2017, 330, pp.1069-1092. ⟨10.1016/j.jcp.2016.09.062⟩
https://hal.science/hal-01395861/file/JCOMP-D-15-01516R2.pdf BibTex
titre
Numerical robustness of single-layer method with Fourier basis for multiple obstacle acoustic scattering in homogeneous media
auteur
Hélène Barucq, Juliette Chabassier, Ha Pham, Sébastien Tordeux
article
Wave Motion, 2017, 77, pp.40-63. ⟨10.1016/j.wavemoti.2017.10.011⟩
https://hal.science/hal-01667176/file/FSSLPaper_WaveMotionJournal_V4.pdf BibTex
2016
titre
Approximation by multipoles of the multiple acoustic scattering by small obstacles and application to the Foldy theory of isotropic scattering.
auteur
Abderrahmane Bendali, Pierre-Henri Cocquet, Sébastien Tordeux
article
Archive for Rational Mechanics and Analysis, 2016, 219 (3), pp.1017-1059. ⟨10.1007/s00205-015-0915-5⟩
https://hal.science/hal-01025436/file/bendali_foldy_model.pdf BibTex
2015
titre
Matched Asymptotic Expansions of the Eigenvalues of a 3-D Boundary-Value Problem Relative to Two Cavities Linked by a Hole of Small Size
auteur
Abderrahmane Bendali, M’barek Fares, Abdelkader Tizaoui, Sébastien Tordeux
article
Communications in Computational Physics, 2015, 11 (2), pp.456-471. ⟨10.4208/cicp.141209.280610s⟩
Accès au bibtex
BibTex
titre
An efficient truncated SVD of large matrices based on the low-rank approximation for inverse geophysical problems
auteur
Sergey Solovyev, Sébastien Tordeux
article
Sibirskie Elektronnye Matematičeskie Izvestiâ, 2015, 12, pp.592-609. ⟨10.17377/semi.2015.12.048⟩
https://hal.science/hal-01414769/file/semr614.pdf BibTex
2014
titre
Effective conditions for the reflection of an acoustic wave by low-porosity perforated plates
auteur
Sophie Laurens, Estelle Piot, Abderrahmane Bendali, M’Barek Fares, Sébastien Tordeux
article
Journal of Fluid Mechanics, 2014, ⟨10.1017/jfm.2014.46⟩
https://hal.science/hal-00769393/file/soumission-jfm.pdf BibTex
2013
titre
Lower and upper bounds for the Rayleigh conductivity of a perforated plate
auteur
Sophie Laurens, Sébastien Tordeux, Abderrahmane Bendali, M’Barek Fares, P. Robert Kotiuga
article
ESAIM: Mathematical Modelling and Numerical Analysis, 2013, 47 (6), pp.1691-1712. ⟨10.1051/m2an/2013082⟩
https://hal.science/hal-00686438/file/publi-rayleigh.pdf BibTex
titre
Mathematical justification of the Rayleigh conductivity model for perforated plates in acoustics
auteur
Abderrahmane Bendali, M’Barek Fares, Estelle Piot, Sébastien Tordeux
article
SIAM Journal on Applied Mathematics, 2013, 73 (1), pp.438-459. ⟨10.1137/120867123⟩
Accès au bibtex
BibTex
titre
Explicit computation of the electrostatic energy for an elliptical charged disc.
auteur
article
Applied Mathematics Letters, 2013, 26 (2), pp.301-305. ⟨10.1016/j.aml.2012.09.013⟩
https://hal.science/hal-00723234/file/elliptique.pdf BibTex
2012
titre
Numerical study of acoustic multiperforated plates
auteur
Abderrahmane Bendali, M’Barek Fares, Sophie Laurens, Sébastien Tordeux
article
ESAIM: Proceedings, 2012, 37, pp.166-177. ⟨10.1051/proc/201237005⟩
https://hal.science/hal-00686434/file/multiperf_acoust.pdf BibTex
titre
Self-adjoint curl operators
auteur
Ralf Hiptmair, P. Robert Kotiuga, Sébastien Tordeux
article
Annali di Matematica Pura ed Applicata, 2012, 191 (3), pp.431-457. ⟨10.1007/s10231-011-0189-y⟩
https://inria.hal.science/inria-00527733/file/selfadjoint.pdf BibTex
titre
Non-reflecting boundary condition on ellipsoidal boundary
auteur
Hélène Barucq, Anne-Gaëlle Dupouy St-Guirons, Sébastien Tordeux
article
Numerical Analysis and Applications, 2012, 5 (2), pp.109-115
Accès au bibtex
BibTex
titre
Scattering of a scalar time-harmonic wave by N small spheres by the method of matched asymptotic expansions
auteur
Sébastien Tordeux, Abderrahmane Bendali, Pierre-Henri Cocquet
article
Numerical Analysis and Applications, 2012, 5 (2), pp.116-123. ⟨10.1134/S1995423912020036⟩
Accès au bibtex
BibTex
titre
Matched Asymptotic Expansions of the Eigenvalues of a 3-D boundary-value problem relative to two cavities linked by a hole of small size
auteur
Abderrahmane Bendali, M’Barek Fares, Abdelkader Tizaoui, Sébastien Tordeux
article
Communications in Computational Physics, 2012, 11 (2), pp.456-471
Accès au bibtex
BibTex
2011
titre
High order transmission conditions for thin conductive sheets in magneto-quasistatics
auteur
Kersten Schmidt, Sébastien Tordeux
article
ESAIM: Mathematical Modelling and Numerical Analysis, 2011, 45 (6), pp.1115-1140. ⟨10.1051/m2an/2011009⟩
https://inria.hal.science/inria-00473213/file/article_KSchmidt_STordeux_Revised_Two.pdf BibTex
titre
Field behavior near the edge of a microstrip antenna by the method of matched asymptotic expansions
auteur
Abderrahmane Bendali, Abdelkader Makhlouf, Sébastien Tordeux
article
Quarterly of Applied Mathematics, 2011, 69, pp.691-721. ⟨10.1090/S0033-569X-2011-01256-3⟩
https://inria.hal.science/inria-00531578/file/BMT.pdf BibTex
titre
Multiscale expansion and numerical approximation for surface defects
auteur
Virginie Bonnaillie-Noël, Delphine Brancherie, Marc Dambrine, Frédéric Hérau, Sébastien Tordeux, Grégory Vial
article
ESAIM: Proceedings, 2011, 33, pp.22-35. ⟨10.1051/proc/201133003⟩
Accès au bibtex
BibTex
2010
titre
Asymptotic modelling of conductive thin sheets
auteur
article
Zeitschrift für Angewandte Mathematik und Physik = Journal of Applied mathematics and physics = Journal de mathématiques et de physique appliquées, 2010, 61 (4), pp.603-626. ⟨10.1007/s00033-009-0043-x⟩
https://inria.hal.science/inria-00527608/file/SchmidtTordeux2010.pdf BibTex
titre
Justification of the cavity model in the numerical simulation of patch antennas by the method of matched asymptotic expansions
auteur
article
Multiscale Modeling and Simulation: A SIAM Interdisciplinary Journal, 2010, 8 (5), pp.1902–1922. ⟨10.1137/090771041⟩
https://inria.hal.science/hal-00644409/file/bmt10.pdf BibTex
titre
Effect of micro-defects on structure failure : coupling asymptotic analysis and strong discontinuity approach
auteur
Virginie Bonnaillie-Noël, Delphine Brancherie, Marc Dambrine, Sébastien Tordeux, Grégory Vial
article
Revue Européenne de Mécanique Numérique/European Journal of Computational Mechanics, 2010, 19 (1-3), pp.165-175. ⟨10.3166/ejcm.19.165-175⟩
Accès au bibtex
BibTex
2009
titre
Asymptotic expansions of the eigenvalues of a 2-D boundary-value problem relative to two cavities linked by a hole of small size
auteur
Abderrahmane Bendali, Alain Huard, Abdelkader Tizaoui, Sébastien Tordeux, Jean-Paul Vila
article
Comptes Rendus. Mathématique, 2009, 347 (19-20), pp.1147-1152. ⟨10.1016/j.crma.2009.09.005⟩
Accès au bibtex
BibTex
titre
auteur
article
Comptes rendus de l’Académie des sciences. Série I, Mathématique, 2009, 347 (19-20), pp.1147–1152. ⟨10.1016/j.crma.2009.09.005⟩
Accès au bibtex
BibTex
titre
Interactions between moderately close inclusions for the Laplace equation
auteur
Virginie Bonnaillie-Noël, Marc Dambrine, Sébastien Tordeux, Grégory Vial
article
Mathematical Models and Methods in Applied Sciences, 2009, 19 (10), pp.1853-1882. ⟨10.1142/S021820250900398X⟩
Accès au bibtex
BibTex
2008
titre
Asymptotic expansion of highly conductive thin sheets
auteur
article
PAMM, 2008, 7, pp.2040011-2040012
Accès au bibtex
BibTex
titre
Matching of asymptotic expansions for waves propagation in media with thin slots. II. The error estimates
auteur
Patrick Joly, Sébastien Tordeux
article
ESAIM: Mathematical Modelling and Numerical Analysis, 2008, 42 (2), pp.193–221. ⟨10.1051/m2an:2008004⟩
Accès au bibtex
BibTex
2007
titre
On moderately close inclusions for the Laplace equation
auteur
article
Comptes Rendus. Mathématique, 2007, 345 (11), pp.609-614. ⟨10.1016/j.crma.2007.10.037⟩
Accès au bibtex
BibTex
2006
titre
Matching and multiscale expansions for a model singular perturbation problem
auteur
Sébastien Tordeux, Grégory Vial, Monique Dauge
article
Comptes Rendus. Mathématique, 2006, 343 (10), pp.637-642. ⟨10.1016/j.crma.2006.10.010⟩
https://hal.science/hal-00453366/file/STGV.pdf BibTex
titre
A mathematical analysis of the resonance of the finite thin slots
auteur
Marianne Clausel, Marc Duruflé, Patrick Joly, Sébastien Tordeux
article
Applied Numerical Mathematics: an IMACS journal, 2006, 56 (10-11), pp.1432-1449
https://hal.science/hal-00404068/file/ClaDurJolTor.pdf BibTex
titre
Asymptotic analysis of an approximate model for time harmonic waves in media with thin slots
auteur
article
ESAIM: Mathematical Modelling and Numerical Analysis, 2006, 40 (1), pp.63–97. ⟨10.1051/m2an:2006008⟩
Accès au bibtex
BibTex
titre
Matching of asymptotic expansions for wave propagation in media with thin slots. I. The asymptotic expansion
auteur
article
Multiscale Modeling and Simulation: A SIAM Interdisciplinary Journal, 2006, 5 (1), pp.304–336 (electronic). ⟨10.1137/05064494X⟩
https://inria.hal.science/inria-00527588/file/JTMMS06.pdf BibTex
