List of GPU resources available (update needed)
There are several GPU clusters around that TAU members can use freely:
- TAU’s own GPU cluster (~50 GPUs 1080 bought in 2018): Titanic
- GPU cluster at CDS – IDRIS (currently 20 GPUs, soon around 70): DSP Cluster
- Ciboulette and Citronelle (small GPU server to play around with, outdated) : see TaoGPUServer
- Jean Zay, national equipment installed in Summer 2019, 1000 GPUs (VT100) + as many CPUs. Secured access, see the connection instructions for INRIA members
(you, if you are reading this text
It’s in French, the English version
is empty as of today (Feb. 18, 2020), but DeepL
is doing a great job translating.
Also, CPU clusters are available:
- TomPouce (CPU cluster) : see Tompouce Tutorial
- obsolete CPU servers : see TaoCPUServer
- Jean Zay (see GPUs above)
