Our Location
General directions
  1. Land on earth
  2. Our location is [ 50.60604, 3.14816 ].
  3. Get to Lille, either by car, train, plane… then
From Lille-Lesquin airport
Two solutions:
  • the fast solution is to catch a cab
  • the cheap solution is to catch the shuttle from the airport to Lille train station
By train + subway
There are two train stations in Lille: Lille-Europe and Lille-Flandres.
  • if you arrive at Lille-Europe, first take the line 2 of the subway (so-called VAL) in the direction of St Philibert, get off at next station which is Gare Lille-Flandres. Then:
  • if you arrive at Lille-Flandres, just take the line 1 of the subway (so-called VAL) to the terminal station 4 Cantons.
From the 4 Cantons station: follow this blue path
By car
  • Take a highway towards Lille, then to Villeneuve d’Ascq when indicated.
  • Then, “4 Cantons” exit.
In case
In case you are lost, you may consider calling (+33).3.59.57.78.00.
