Category: Seminars Monaldo Mastrolilli: High Degree Sum of Squares Proofs/Hierarchy for 0/1 Problems (LIG/VERIMAG seminar)
February 16, 2017
Prof. Monaldo Mastrolilli, IDSIA Lugano
http://people.idsia.ch/~monaldo/
The Lasserre/Sum-of-Squares (SOS) hierarchy is a systematic procedure for constructing a sequence of increasingly tight semidefinite relaxations. It is known that the hierarchy converges to the 0/1 polytope in n levels and captures the convex relaxations used in the best available approximation algorithms for a wide variety of optimization problems.
In this talk I will give a gentle introduction of the SOS framework for 0/1 problems from a more general point of view.
I will point it out that this more general definition is needed for certain class of problems, it removes some of the weakness of the standard SOS approach.
Bâtiment IMAG (amphitheater)
Saint-Martin-d'Hères, 38400
France
View full calendar
Comments are closed.
