January 14, 2016
We consider a sequential learning problem with Gaussian payoffs and side observations: after selecting an action i, the learner receives information about the payoff of every action j in the form of Gaussian observations whose mean is the same as the mean payoff, but the variance depends on the pair (i,j) (and may be infinite). The setup allows a more refined information transfer from one action to another than previous partial monitoring setups, including the recently introduced graph-structured feedback case. For the first time in the literature, we provide non-asymptotic problem-dependent lower bounds on the regret of any algorithm, which recover existing asymptotic problem-dependent lower bounds and finite-time minimax lower bounds available in the literature. We also provide algorithms that achieve the problem-dependent lower bound (up to some universal constant factor) or the minimax lower bounds (up to logarithmic factors). Based on joint work with Yifan Wu and Csaba Szepesvari.
