Data-driven HRF estimation
Data-driven HRF estimation for resting state and task fMRI data
Related papers are here and here
The estimation of the haemodynamic response function (HRF) in functional magnetic imaging (fMRI) is critical to get insights on subject vascular health in the brain. Existing methods propose to estimate the HRF using the experimental paradigm (EP) in task fMRI as a surrogate of the neural activity, thus these approaches are not available for resting-state fMRI data. In this work, we formulate the joint estimation of the HRF and the neural activation signal as a semi blind deconvolution problem based on a rank constraint along with a sparsity promotion which accomodate to both resting-state fMRI and task fMRI data.
Illustration of our hemodynamic response function estimation framework
Code available is here.
The dictionary learning approach developped here is related to the work described here.
Data-driven HRF estimation for encoding and decoding models
Full paper on HAL
Despite the common usage of a canonical, data-independent, hemodynamic response function (HRF), it is known that the shape of the HRF varies across brain regions and subjects. This suggests that a data-driven estimation of this function could lead to more statistical power when modeling BOLD fMRI data. However, unconstrained estimation of the HRF can yield highly unstable results when the number of free parameters is large. We develop a method for the joint estimation of activation and HRF using a rank constraint causing the estimated HRF to be equal across events/conditions, yet permitting it to be different across voxels. Model estimation leads to an optimization problem that we propose to solve with an efficient quasi-Newton method exploiting fast gradient computations. This model, called GLM with Rank-1 constraint (R1-GLM), can be extended to the setting of GLM with separate designs which has been shown to improve decoding accuracy in brain activity decoding experiments. We compare 10 different HRF modeling methods in terms of encoding and decoding score in two different datasets. Our results show that the R1-GLM model significantly outperforms competing methods in both encoding and decoding settings, positioning it as an attractive method both from the points of view of accuracy and computational efficiency.
hrf
Illustration of our hemodynamic response function estimation framework.
