STIMUL
STiMuL: steady temperature in multi-layers
Language: C
OS: Linux
Required: FFTW
Download: stimul-1.2
Documentation
STiMuL is a C library for modeling steady-state heat conduction in microprocessors. It can be used to obtain temperature from power density or power density from temperature. It can also be used to model stacked dies. STiMuL does not model time-varying temperature. For time-varying temperature, other models must be used, such as ATMI.
Contact: Pierre Michaud
