All the abstractions of the Researchers160k dataset leads to the same output: one main entity (the researchers), looping on itself with the “top-5-coauthors” relationship.
Strictly Necessary Cookies
Strictly Necessary Cookie should be enabled at all times so that we can save your preferences for cookie settings.
If you disable this cookie, we will not be able to save your preferences. This means that every time you visit this website you will need to enable or disable cookies again.
