AFF3CT
AFF3CT: Fast Forward Error Correction Simulation Toolbox
Polar error correction code decoding performance using AFF3CT
AFF3CT is an Open-source software (MIT license) dedicated to the Forward Error Correction (FEC or channel coding) simulations. It is written in C++11 and it supports a large range of codes: from the well-spread Turbo codes to the very new Polar codes including the Low-Density Parity-Check (LDPC) codes. A particular emphasis is given to the simulation throughput performance (hundreds of Mb/s on today’s CPUs) and the portability of the code.
AFF3CT homepage
