OpticalFlow
OpticalFlow software
Overview
Optical-flow is a software for estimation of the optical flow between a pair of images. It implements the method described in [1] improved by several features of [2]. As pre-processing steps, image equalization using [3] and dominant motion compensation using the Motion2D software [4,5] are optionally proposed.
OpticalFlow demonstration
You can try OpticalFlow on our mobyle web portal: Try OpticalFlow
References
  • T. Brox, A. Bruhn, N. Papenberg, and J. Weickert. High accuracy optical flow estimation based on a theory for warping. In Proc. ECCV 2004, pages 25–36, 2004.
  • H. Zimmer, A. Bruhn, and J. Weickert. Optic flow in harmony. Int. J. Comp. Vis., pages 1–21, 2011.
  • J. Delon. Midway image equalization. J. Math. Imaging Vis., 21(2):119–134, 2004.
  • J.M. Odobez and P. Bouthemy. Robust multiresolution estimation of parametric motion models. J. Vis. Comm. Image Repres., 6(4):348–365, 1995.
  • http://www.irisa.fr/vista/Motion2D/index.html
