PhD Offers
- Dynamic load balancing for massively parallel coupled codes [pdf]
- Task-based programming paradigms and scheduling [pdf]
Postdoc Offers
- High performance solver for simulation of 3D hypersonic flows on Petascale supercomputers in collaboration with CEA-CESTA in teh framework of the cluster of excellence CPU from the University of Bordeaux [pdf]
- Parallel hybrid solver for DG linear systems in the 3D time-harmonic Maxwell équations with application to radar cross section evaluation [pdf] in the framework of the ANR TECSER in collboaration with Inria teams Corrida and Nachos, and Airbus and the Nucletude company
- Enabling Climate simulation at Extreme Scale: G8 project [pdf] in the framework of the G8-ECS project
- On the use of H-matrix arithmetic for the design of hierarchical parallel sparse linear
solvers [pdf] - Parallel Geometric Full Multigrid Solver [pdf]
- Parallel eigensolvers in Computational Chemistry
- Exascale Algorithms and Advanced Computational Techniques : Krylov solvers for extreme scale [pdf] in the framework of the European FP7 Exa2CT project
Engineer Offers
Internship Positions – Spring 2014
Master internship subject, that can be continued within a PhD
- Design and integration of non regression test suite for HighPerformance Computing (HPC) simulations [pdf]
- Etude de performances d’un solveur direct creux sur architecture Intel Xeon Phi (MIC) [pdf]
- On the use of H-matrix arithmetic for the design of hierarchical parallel sparse linear solvers [pdf]
- Optimisation et restructuration du logiciel ViTE [pdf]
- Development of a DAG visualization tool (ICL, Knoxville, USA – Tennessee)[pdf]
- Construction et partage d’un arbre en parallélisation hybride. (HPC) [pdf]
- Intégration d’une méthode de multipôles rapide dans un code de dynamique moléculaire parallèle.(HPC)[pdf]
